Victor-Yout Posted October 27, 2021 Posted October 27, 2021 i never tried VPN till today, but there is no way i'm using VPN if my connection looks like this. 45% packet loss and just 20 out of 250 mpbs. am i doing something wrong?
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 A VPN does add more hops and more latency so that is to be expected. The speed will also be reduced using the router as the client, we'll be able to improve on this in future I believe. The packet loss is a little odd though, it may be a bad server so try another and see if it is any better.
Victor-Yout Posted October 27, 2021 Author Posted October 27, 2021 same server but vpn set up directly on my pc, 0% packet loss and same speeds as without VPN
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 I would expect the speed to be different, that is normal, where abouts is the VPN server location?
Victor-Yout Posted October 27, 2021 Author Posted October 27, 2021 frankfurt germany, but i tried others with the same result
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 Do you have Adblocker or the Geo-Filter enabled? What is the modem model the R2 is connected to?
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 How is the fritz setup - with the XR in the DMZ, bridge/modem mode? What firmware version are you on for the XR? How is the Macbook connected to the router, over WiFi?
Victor-Yout Posted October 28, 2021 Author Posted October 28, 2021 modem/router with the xr in DMZ. 2.3.2.56. wired tried with the r2 with the same result
Administrators Netduma Fraser Posted October 28, 2021 Administrators Posted October 28, 2021 Set the VPN IP address as the router DNS, then retest, do you get the same packet loss?
Administrators Netduma Fraser Posted October 28, 2021 Administrators Posted October 28, 2021 Change to Only VPN these services and just add the ports the speedtest requires: https://support.ookla.com/hc/en-us/articles/360027274852-Which-Ports-Am-I-Required-to-Use- and test again please
Victor-Yout Posted October 29, 2021 Author Posted October 29, 2021 it then shows me my actual location and ip, but i dont know if its set up correctly
Administrators Netduma Fraser Posted October 29, 2021 Administrators Posted October 29, 2021 Looks like they use other ports as well, add 443 as a port there and see if location changes and whether the speed is lowered again with zero packet loss
Administrators Netduma Fraser Posted October 29, 2021 Administrators Posted October 29, 2021 What VPN are you using? Can you provide the config file?
Victor-Yout Posted October 29, 2021 Author Posted October 29, 2021 my_expressvpn_germany_-_frankfurt_-_1_udp.ovpn
Administrators Netduma Fraser Posted October 29, 2021 Administrators Posted October 29, 2021 I'm not sure how it managed to connect with that config actually, can you try this instead and go back to Do NOT VPN these services please and see if it works better: client dev tun fast-io persist-key persist-tun nobind remote germany-frankfurt-1-ca-version-2.expressnetw.com 1195 pull comp-lzo no tls-client verify-x509-name Server name-prefix ns-cert-type server key-direction 1 route-method exe route-delay 2 tun-mtu 1500 fragment 1300 mssfix 1200 verb 3 cipher AES-256-CBC keysize 256 auth SHA512 sndbuf 524288 rcvbuf 524288 auth-user-pass <ca> -----BEGIN CERTIFICATE----- MIIF+DCCA+CgAwIBAgIBATANBgkqhkiG9w0BAQ0FADCBhDELMAkGA1UEBhMCVkcx DDAKBgNVBAgMA0JWSTETMBEGA1UECgwKRXhwcmVzc1ZQTjETMBEGA1UECwwKRXhw cmVzc1ZQTjEWMBQGA1UEAwwNRXhwcmVzc1ZQTiBDQTElMCMGCSqGSIb3DQEJARYW c3VwcG9ydEBleHByZXNzdnBuLmNvbTAeFw0xNTEwMjEwMDAwMDBaFw0yNjA0MDEy MTEyMDBaMIGEMQswCQYDVQQGEwJWRzEMMAoGA1UECAwDQlZJMRMwEQYDVQQKDApF eHByZXNzVlBOMRMwEQYDVQQLDApFeHByZXNzVlBOMRYwFAYDVQQDDA1FeHByZXNz VlBOIENBMSUwIwYJKoZIhvcNAQkBFhZzdXBwb3J0QGV4cHJlc3N2cG4uY29tMIIC IjANBgkqhkiG9w0BAQEFAAOCAg8AMIICCgKCAgEAxzXvHZ25OsESKRMQFINHJNqE 9kVRLWJS50oVB2jxobudPhCsWvJSApvar8CB2RrqkVMhXu2HT3FBtDL91INg070q AyjjRpzEbDPWqQ1+G0tk0sjiJt2mXPJK2IlNFnhe6rTs09Pkpcp8qRhfZay/dIlm agohQAr4JvYL1Ajg9A3sLb8JkY03H6GhOF8EKYTqhrEppCcg4sQKQhNSytRoQAm8 Ta+tnTYIedwWpqjUXP9YXFOvljPaixfYug24eAkpTjeuWTcELSyfnuiBeK+z9+5O YunhqFt2QZMq33kLFZGMN2gHRCzngxxphurypsPRo7jiFgQI1yLt8uZsEZ+otGEK 91jjKfOC+g9TBy2RUtxk1neWcQ6syXDuc3rBNrGA8iM0ZoEqQ1BC8xWr3NYlSjqN +1mgpTAX3/Dxze4GzHd7AmYaYJV8xnKBVNphlMlg1giCAu5QXjMxPbfCgZiEFq/u q0SOKQJeT3AI/uVPSvwCMWByjyMbDpKKAK8Hy3UT5m4bCNu8J7bxj+vdnq0A2HPw tF0FwBl/TIM3zNsyFrZZ0j6jLRT50mFsgDBKcD4L/J5rjdCsKPu5rodhxe38rCx2 GknP1Zkov4yoVCcR48+CQwg3oBkq0/EflvWUvcYApzs9SomUM/g+8Q/V0WOfJmFW uxN9YntZlnzHRSRjrvMCAwEAAaNzMHEwHQYDVR0OBBYEFIzmQGj8xS+0LLklwqHD 45VVOZRJMB8GA1UdIwQYMBaAFIzmQGj8xS+0LLklwqHD45VVOZRJMA8GA1UdEwEB /wQFMAMBAf8wCwYDVR0PBAQDAgEGMBEGCWCGSAGG+EIBAQQEAwIBFjANBgkqhkiG 9w0BAQ0FAAOCAgEAbHfuMKtojm1NgX7qSU2Rm2B5L8G0FuFP0L40dj8O5WHt45j2 z8coMK90vrUnQEZNQmRzot7v3XjVzVlxBWYSsCEApTsSDNi/4BNFP8H/BUUtJuy2 GFTO4wDVJnqNkZOHBmyVD75s1Y+W8a+zB4jkMeDEhOHZdwQ0l1fJDDgXal5f1UT5 F5WH6/RwHmWTwX4GxuCiIVtx70CjkXqhM8yZtTp1UtHLRNYcNSIes0vrAPHPgoA5 z9B8UvsOjuP+mfcjzi0LGGrY+2pJu0BKO2dRnarIZZABETIisI3FokoTszx5jpRP yxyUTuRDKWHrvi0PPtOmC8nFahfugWFUi6uBsqCaSeuex+ahnTPCq0b1l0Ozpg0Y eE8CW1TL9Y92b01up2c+PP6wZOIm3JyTH+L5smDFbh80V42dKyGNdPXMg5IcJhj3 YfAy4k8h/qbWY57KFcIzKx40bFsoI7PeydbGtT/dIoFLSZRLW5bleXNgG9mXZp27 0UeEC6CpATCS6uVl8LVT1I02uulHUpFaRmTEOrmMxsXGt6UAwYTY55K/B8uuID34 1xKbeC0kzhuN2gsL5UJaocBHyWK/AqwbeBttdhOCLwoaj7+nSViPxICObKrg3qav GNCvtwy/fEegK9X/wlp2e2CFlIhFbadeXOBr9Fn8ypYPP17mTqe98OJYM04= -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- MIIDTjCCAregAwIBAgIDKzZvMA0GCSqGSIb3DQEBCwUAMIGFMQswCQYDVQQGEwJV UzELMAkGA1UECBMCQ0ExFTATBgNVBAcTDFNhbkZyYW5jaXNjbzEVMBMGA1UEChMM Rm9ydC1GdW5zdG9uMRgwFgYDVQQDEw9Gb3J0LUZ1bnN0b24gQ0ExITAfBgkqhkiG 9w0BCQEWEm1lQG15aG9zdC5teWRvbWFpbjAgFw0xNjExMDMwMzA2MThaGA8yMDY2 MTEwMzAzMDYxOFowgYoxCzAJBgNVBAYTAlZHMQwwCgYDVQQIDANCVkkxEzARBgNV BAoMCkV4cHJlc3NWUE4xEzARBgNVBAsMCkV4cHJlc3NWUE4xHDAaBgNVBAMME2V4 cHJlc3N2cG5fY3VzdG9tZXIxJTAjBgkqhkiG9w0BCQEWFnN1cHBvcnRAZXhwcmVz c3Zwbi5jb20wggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCrOYt/KOi2 uMDGev3pXg8j1SO4J/4EVWDF7vJcKr2jrZlqD/zuAFx2W1YWvwumPO6PKH4PU962 1aNdiumaUkv/RplCfznnnxqobhJuTE2oA+rS1bOq+9OhHwF9jgNXNVk+XX4d0toS T5uGE6Z3OdmPBur8o5AlCf78PDSAwpFOw5HrgLqOEU4hTweC1/czX2VsvsHv22HR I6JMZgP8gGQii/p9iukqfaJvGdPciL5p1QRBUQIi8P8pNvEp1pVIpxYj7/LOUqb2 DxFvgmp2v1IQ0Yu88SWsFk84+xAYHzfkLyS31Sqj5uLRBnJqx3fIlOihQ50GI72f wPMwo+OippvVAgMBAAGjPzA9MAwGA1UdEwEB/wQCMAAwDgYDVR0PAQH/BAQDAgSw MB0GA1UdDgQWBBSkBM1TCX9kBgFsv2RmOzudMXa9njANBgkqhkiG9w0BAQsFAAOB gQA+2e4b+33zFmA+1ZQ46kWkfiB+fEeDyMwMLeYYyDS2d8mZhNZKdOw7dy4Ifz9V qzp4aKuQ6j61c6k1UaQQL0tskqWVzslSFvs9NZyUAJLLdGUc5TT2MiLwiXQwd4Uv H6bGeePdhvB4+ZbW7VMD7TE8hZhjhAL4F6yAP1EQvg3LDA== -----END CERTIFICATE----- </cert> <key> -----BEGIN RSA PRIVATE KEY----- MIIEpAIBAAKCAQEAqzmLfyjotrjAxnr96V4PI9UjuCf+BFVgxe7yXCq9o62Zag/8 7gBcdltWFr8Lpjzujyh+D1PettWjXYrpmlJL/0aZQn85558aqG4SbkxNqAPq0tWz qvvToR8BfY4DVzVZPl1+HdLaEk+bhhOmdznZjwbq/KOQJQn+/Dw0gMKRTsOR64C6 jhFOIU8Hgtf3M19lbL7B79th0SOiTGYD/IBkIov6fYrpKn2ibxnT3Ii+adUEQVEC IvD/KTbxKdaVSKcWI+/yzlKm9g8Rb4Jqdr9SENGLvPElrBZPOPsQGB835C8kt9Uq o+bi0QZyasd3yJTooUOdBiO9n8DzMKPjoqab1QIDAQABAoIBAHgsekC0SKi+AOcN OZqJ3pxqophE0V7fQX2KWGXhxZnUZMFxGTc936deMYzjZ1y0lUa6x8cgOUcfqHol 3hDmw9oWBckLHGv5Wi9umdb6DOLoZO62+FQATSdfaJ9jheq2Ub2YxsRN0apaXzB6 KDKz0oM0+sZ4Udn9Kw6DfuIELRIWwEx4w0v3gKW7YLC4Jkc4AwLkPK03xEA/qImf kCmaMPLhrgVQt+IFfP8bXzL7CCC04rNU/IS8pyjex+iUolnQZlbXntF7Bm4V2mz0 827ZVqrgAb/hEQRlsTW3rRkVh+rrdoUE7BCZRTFmRCbLoShjN6XuSf4sAus8ch4U EN12gN0CgYEA4o/tSvij1iPaXLmt4KOEuxqmSGB8MLKhFde8lBbNdrDgxiIH9bH7 khKx15XRTX0qLDbs8b2/UJygZG0Aa1kIBqZTXTgeMAuxPRTesALJPdqQ/ROnbJcd FkI7gllrAG8VB0fH4wTRsRd0vWEB6YlCdE107u6LEsLAHxOj9Q5819cCgYEAwXjx 9RkQ2qITBx5Ewib8YsltA0n3cmRomPicLlsnKV5DfvyCLpFIsZ1h3f9dUpfxRLwz p8wcoLiq9cCoOGdu1udw/yBTqmhaXWhUK/g77f9Ze2ZB1OEhuyKLYJ1vW/h/Z/a1 aPCMxZqsDTPCePsuO8Cez5gqs8LjM3W7EyzRxDMCgYEAvhHrDFt975fSiLoJgo0M PIAGAnBXn+8sLwv3m/FpW+rWF8LTFK/Fku12H5wDpNOdvswxijkauIE+GiJMGMLv dcyx4WHECaC1h73reJRNykOEIZ0Md5BrCZJ1JEzp9Mo8RQhWTEFtvfkkqgApP4g0 pSeaMx0StaGG1kt+4IbP+68CgYBrZdQKlquAck/Vt7u7eyDHRcE5/ilaWtqlb/xi zz7h++3D5C/v4b5UumTFcyg+3RGVclPKZcfOgDSGzzeSd/hTW46iUTOgeOUQzQVM kzPRXdoyYgVRQtgSpY5xR3O1vjAbahwx8LZ0SvQPMBhYSDbV/Isr+fBacWjl/Aip EEwxeQKBgQDdrAEnVlOFoCLw4sUjsPoxkLjhTAgI7CYk5NNxX67Rnj0tp+Y49+sG Uhl5sCGfMKkLShiON5P2oxZa+B0aPtQjsdnsFPa1uaZkK4c++SS6AetzYRpVDLmL p7/1CulE0z3O0sBekpwiuaqLJ9ZccC81g4+2j8j6c50rIAct3hxIxw== -----END RSA PRIVATE KEY----- </key> <tls-auth> # # 2048 bit OpenVPN static key # -----BEGIN OpenVPN Static key V1----- 48d9999bd71095b10649c7cb471c1051 b1afdece597cea06909b99303a18c674 01597b12c04a787e98cdb619ee960d90 a0165529dc650f3a5c6fbe77c91c137d cf55d863fcbe314df5f0b45dbe974d9b de33ef5b4803c3985531c6c23ca6906d 6cd028efc8585d1b9e71003566bd7891 b9cc9212bcba510109922eed87f5c8e6 6d8e59cbd82575261f02777372b2cd4c a5214c4a6513ff26dd568f574fd40d6c d450fc788160ff68434ce2bf6afb00e7 10a3198538f14c4d45d84ab42637872e 778a6b35a124e700920879f1d003ba93 dccdb953cdf32bea03f365760b0ed800 2098d4ce20d045b45a83a8432cc73767 7aed27125592a7148d25c87fdbe0a3f6 -----END OpenVPN Static key V1----- </tls-auth>
Administrators Netduma Fraser Posted October 29, 2021 Administrators Posted October 29, 2021 What MTU do you have set on the router?
Administrators Netduma Fraser Posted October 29, 2021 Administrators Posted October 29, 2021 Can you change it to 1500 on the router please and see if there is a difference? If not I think I'll need to pass on to a dev and see what they think it could be
Administrators Netduma Fraser Posted November 2, 2021 Administrators Posted November 2, 2021 Okay no worries, I'll pass on to a dev and will get back to you.
Administrators Netduma Fraser Posted November 4, 2021 Administrators Posted November 4, 2021 Do you experience this with any other VPN provider through HybridVPN? If you haven't tried could you try one, perhaps one with a free trial?
