yeastral Posted June 27, 2021 Posted June 27, 2021 Hello, my connection benchmark and auto setup for qos is not working. I have factory reset the router manually and still not working. The connection benchmark just says its loading and nothing happens. Auto setup for qos just says best settings found straight away which is always 100 percent for both download and upload. I have the remote access for tech support ticked as well. Any help or suggestions would be appreciated. Astral
Administrators Netduma Fraser Posted June 27, 2021 Administrators Posted June 27, 2021 What firmware version are you using and what web browser/device are you using to access the interface?
Administrators Netduma Fraser Posted June 27, 2021 Administrators Posted June 27, 2021 Did you update to .205 yourself or was it already present when you purchased? What device are you using? Can you provide a full screenshot including the browser showing what you see on both Congestion Control and QoS please?
yeastral Posted June 27, 2021 Author Posted June 27, 2021 The auto setup one just does the same thing everytime says its found the best settings straight away and doesnt change from 100 percent. The benchmark you just click the start buttonand nothing happens.
Administrators Netduma Fraser Posted June 27, 2021 Administrators Posted June 27, 2021 Did you update to .205 yourself or was it already present when you purchased? Are you using an Adblocker on the web browser? If you open it in an incognito window does it work?
