Wingingbubble Posted May 29, 2021 Posted May 29, 2021 Need Help with settings this is my connection Test . I mostly play Destiny 2 guild wars 2 final fantasy online and genshin impact so would be nice if i can get the best out of my router (XR1000) also i live in pakistan so guidance would be much appreciated if anyone can help me figure out these settings because i am not that bright when it comes to these things lol
Administrators Netduma Fraser Posted May 29, 2021 Administrators Posted May 29, 2021 We're still improving the reporting of results for Connection Benchmark on the XR routers so I'd take them with a pinch of salt but your base ping is very good. On Congestion Control select Always and lower the upload percentage to 50% then do another Connection Benchmark and post the results please. Can then see if it's adjusting or whether we should ignore it.
Wingingbubble Posted May 29, 2021 Author Posted May 29, 2021 this is basically what i got after the 50% reduction
Administrators Netduma Fraser Posted May 29, 2021 Administrators Posted May 29, 2021 Wow okay that's brilliant! That's literally as optimal as you can get for QoS! If you don't want to have 50% upload all the time you can switch that to Auto-Enable so it only applies when you're gaming
