PS5 and PS4 Pro LAN setup
Jeff Gazelle
Check the IP address on the PS4 itself, then double check this with the Device Manager, it may be appearing as another device, then you can rename it so you can add it to the Geo-Filter
ExpressVPN is a VPN provider that you can use for privacy reasons, to appear as though you're in another country etc. I assume they apply it to the console to appear as though they are elsewhere. It will add more lag though so I'd suggest looking into it more before you do anything like that.
