Hybrid VPN Help
HydroYo
Good day,
I am very new to VPNs and the Netduma. I recently got the HideMyAss VPN for attemping to use it with the netduma to perhaps get better lobbies in Warzone.
However, i am unable to get the vpn to connect thru the dumaos. Also when I turn on the VPN thru the HMA software, I lose connection to my dumaos.
Edit: I looked at the advanced tab as well, and tried using the OVPN file, and it didn't work. I also tried UDP and TCP. TCP Fails, UDP never connects.
If someone a lot smarter than me could help me out, that would be appreciated!!
Cheers,
Hydro
You will need to use the Advanced setup for the moment, can you provide the OpenVPN configuration file you're using please?
Could you try a factory reset and then use the same file please? Someone else had the same problem and that resolved it for them
Ok will try that now. For the file, do I just open it in notepad, select all, copy, and then legit just paste that into the field under advanced?
  • 1 month later...
On 8/5/2021 at 20:49, Netduma Fraser said:
Potresti provare a ripristinare le impostazioni di fabbrica e quindi utilizzare lo stesso file per favore? Qualcun altro ha avuto lo stesso problema e questo lo ha risolto per loro
hello expert
If I reset my xr500 to factory settings and connect to a vpn with config file, will the game give me that i'm connected in the vpn location?
