Help Adding CyberGhost to my R2
I’m trying to connect my CyberGhost vpn to my R2 by using openVPN in the advanced page of hybrid vpn
i haven’t been able to put the configuration in because I’m not properly moving the files to the openVPN config file. After I do that step in told to go to openVPN with administration permission and when I press connect it says fail to connect.
Please help!
The R2 has HybridVPN implemented as well. The R2 runs DumaOS, I would not advise you put another operating system as you won't be able to get back to DumaOS and it will void your warranty
I just want to use my cyberghost vpn on dumaOS! I tried connecting it but i got stuck while following the instructions on how to connect it. I was asking cyberghost support and they were asking if the R2 supports the use of openVPN! I'm kinda lost my self..
I really just want to get everything to work
Try this:
client
remote 94-1-mx.cg-dialup.net 443
dev tun
proto udp
auth-user-pass
resolv-retry infinite
redirect-gateway def1
persist-key
persist-tun
nobind
cipher AES-256-CBC
ncp-disable
auth SHA256
ping 5
ping-exit 60
ping-timer-rem
explicit-exit-notify 2
script-security 2
remote-cert-tls server
route-delay 5
verb 4
ca ca.crt
cert client.crt
key client.key
<ca>
-----BEGIN CERTIFICATE-----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==
-----END CERTIFICATE-----
</ca>
<cert>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</cert>
<key>
-----BEGIN PRIVATE KEY-----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-----END PRIVATE KEY-----
</key>
  1. Quit the game to console dashboard / game client completely - including from the System tray (if PC)
  2. Remove device from the Geo-Filter
  3. Resync the cloud
  4. Re-add the device to the Geo-Filter and select the manual option
  5. Set up your radius to cover a further away server - keep Ping Assist on 0
  6. Wait 2 minutes
  7. Boot up the game
Using a VPN adds more latency so I wouldn't recommend it for gaming, especially not forcing servers so far away. Speeds are reduced using it on the router but it is plenty for gaming. We'll have to look at the VPN not working with the filter but it should put you on servers in that location with the VPN
Yes the hybrid-vpn was working and getting my into games! The only problem was I was limited to 6 download speed almost if like QOS was working but I had everything off! The geo filter with the hybrid vpn was not working because I couldn’t find any servers and I know when it’s working because if filter mode is on I can’t join a discord channel without allowing it or going into spectator mode.
When i use CyberGhost vpn normally (not Integrated with duma0S) I was getting 53 download and 38 upload
VPN turned off I get 300 upload and download
with hybrid vpn I get 6 up 6 down
  • 1 year later...
On 5/9/2021 at 7:17 PM, Netduma Fraser said:
Try this:
client
dev tun
proto udp
auth-user-pass
persist-key
persist-tun
nobind
cipher AES-256-CBC
ncp-disable
auth SHA256
ping 5
ping-exit 60
ping-timer-rem
script-security 2
route-delay 5
verb 4
ca ca.crt
cert client.crt
key client.key
<ca>
</ca>
<cert>
</cert>
<key>
</key>
fraser hola, estoy usando el mismo vpn y no logro conectarme, pudieras ayudarme a darme unas instrucciones de como pegar todas las carpetas y formar una sola? gracias
Hola, si pudieras abrir un tema nuevo e incluir los archivos que has descargado para la VPN ahí te puedo aconsejar mejor que hacer.
 Share
