Need Help! what speedtest do i rely on?
Ameryjr
Hello Duma Army! 😎
i have the Netduma R1 version 3.0.207 ( which has been incredible)  (i know i need to upgrade) i pay for 1000gb down 35 upload
 my concern is the download! i understand MY R1 qos is not going to get anything higher than 250 mbps for download
i recieve 400-600 with qos disabled so im fine on the speed part!
      BUT! 🙄
  what (Speed Test) should i rely on so i can implement my bandwith speeds!
when i do speedtests on my (PC) Wired! i get these results from these speed tests with QOS turned on (I Want Qos On)
its the speedtest i should rely on im focusing on!
Speedtest.net -210-215mbps consistent
xfinity.com-200-240 always between this
fast.com -230 mbps consistent
but when i do tests from Dumaos Connection Benchmark i get 156-159 download ( Consistently )
what speedtest should i rely on the most? so i can configure my network optimally ♥
Thank you! 🤙
Hey! We are actually working on ensuring that Connection Benchmark is reporting speeds more accurately so I'd go with the results reported by the three third-party speedtests you've done there.
What are you looking to find out/test from these results? You'll see higher speeds on these websites if you have QoS fully disabled from the three-line menu in Congestion Control, however if you're just looking to see if Congestion Control is working then hopefully that answers your question!
Question answered thank you! I was just wondering what speedtest to rely on! Congestion control works great💯🤝
