adam01625 Posted April 5, 2021 Posted April 5, 2021 Hi there, When accessing netduma on my iPad, whenever I make a change, on the geofilter, I get the warning message pop up about the radius being too small, which is fine, but I can’t close it down as the screen goes dark -
Newfoundland Posted April 6, 2021 Posted April 6, 2021 Duma is not fully compatible with running on the mobile browsers, are you able to access it via a Mac or PC?
adam01625 Posted April 6, 2021 Author Posted April 6, 2021 1 hour ago, Newfie said: Duma is not fully compatible with running on the mobile browsers, are you able to access it via a Mac or PC? Hi, no not at the moment unfortunately
Newfoundland Posted April 6, 2021 Posted April 6, 2021 Have you tried a private browser setting? if not you could try other browsers to see if you can get round it that way.
Administrators Netduma Fraser Posted April 6, 2021 Administrators Posted April 6, 2021 We have a DumaOS app that can run on the tablet, search for DumaOS in the app store on your device
adam01625 Posted April 6, 2021 Author Posted April 6, 2021 1 hour ago, Netduma Fraser said: We have a DumaOS app that can run on the tablet, search for DumaOS in the app store on your device Hi Fraser, I tried that but I don’t think it works with an xr300?
Administrators Netduma Fraser Posted April 6, 2021 Administrators Posted April 6, 2021 Ah my apologies, that's right, it's only for DumaOS 3.0. You could try Google Chrome or Firefox on the tablet, they are more supported but we haven't optimized for mobile devices - hence developing an app
