Murong Posted March 31, 2021 Posted March 31, 2021 Hi, I have a new finding about XR1000. My Internet speed by ISP is DL/UL 300/100 Mbps. But It seems that XR1000 always set the baseline speed for Congestion control as DL/UL: 93/40 Mbps. My question is what is the maximum Internet speed if the QoS is enabled.
pollutionblues Posted March 31, 2021 Posted March 31, 2021 You need to set your correct speeds in Congestion Control. Go to QoS page and open the burger menu on Congestion Control, click on ‘Set Bandwidth Speeds’ and enter your actual speeds
Administrators Netduma Fraser Posted March 31, 2021 Administrators Posted March 31, 2021 As above, please do that and it should work. Don't worry about the speed portion of the test at the moment we're still improving that, check using speedtest.net and you should get the speeds, the router is perfectly capable of reaching them.
Murong Posted March 31, 2021 Author Posted March 31, 2021 Thank you, I find this parameters. It is not easy to find.
