I need help setting up my R2. Having problems with network security key mismatch.
I am trying to set up my R2 router. However I encountered an error and hit the reset button to set it back to factory settings. I also rebooted the router by unplugging it for 30 seconds and I made sure that the cord was connected into Port one and put in the password that was on the underside of the router. However I keep getting the message network security key mismatch. I don't know what to do and I'm about to send the router back. I'm furious this should be a plug-and-play situation but it's been anything but that. I've already spent two hours going back and forth trying every possible scenario. I need help immediately
Is there anyone out there in netduma that can help me? Otherwise I just have to send this thing back and get my money back tomorrow
Unfortunately even though I can connect to the net while I'm hard-wired I still can't I access the internet wirelessly
Hi,
Welcome to the forum.
Follow the password conversion method here:
http://support.netduma.com/en/support/solutions/articles/16000117883-i-ve-received-the-r2-but-the-wifi-password-doesn-t-work
Sorry to hear you're having this issue, did the password conversion method linked above resolve the issue for you?
