TxFrog33 Posted March 13, 2021 Posted March 13, 2021 need help my Geofilter isn't showing any servers after this Power Outage I had, and My QOS is only showing my pc under traffic prioritization is working on my xbox its not showing any packets moving or being prioritized. can someone help me with this?
Administrators Netduma Fraser Posted March 13, 2021 Administrators Posted March 13, 2021 I'd suggest you first unplug the router from the power for 10 minutes to let any residual power drain. Then plug it in and wait 2 minutes before you access the interface, then see if those features are working properly.
TxFrog33 Posted March 13, 2021 Author Posted March 13, 2021 under my device connections it kept showing my xbox was offline I had to change the IP address then it is now showing but the Traffic Priortization is still not showing any packet transfers for XBOX only pc do I need to allow all duma OS games and individually put my devices?
Administrators Netduma Fraser Posted March 13, 2021 Administrators Posted March 13, 2021 How have you added the Xbox to traffic prioritization exactly? I'd suggest using DumaOS Classified Games or adding them individually, not both
TxFrog33 Posted March 14, 2021 Author Posted March 14, 2021 I press add and find my xbox using the device name, also my ping test under load is very weird tonight i have really high download and the only way to get upload lower is to have QOS set to always
Administrators Netduma Fraser Posted March 14, 2021 Administrators Posted March 14, 2021 It looks like the Xbox is prioritizing packets normally there. Connection Benchmark will respond to Always, you'll need to get the best settings to bring it down using Always, then you can switch to Auto-Enable if you like but if you want to test again you'll need to switch back to Always.
