mohands Posted February 14, 2021 Posted February 14, 2021 Hi, I had XR500 before, it was working perfectly with IPTV with VLAN bridge. Now I bought the XR1000, and it is a nice router, but the IPTV doesn't work properly. I activated the VLAN bridge, but still the channels shuttering and not working properly. I tested it on another router with mode bridge, it works perfectly. I rested the XR1000 multiple times, and the same problem exists.
Administrators Netduma Fraser Posted February 14, 2021 Administrators Posted February 14, 2021 Are there any settings you changed specifically on the XR500 that you have yet to put in the XR1000 or are you using the exact same settings?
mohands Posted February 15, 2021 Author Posted February 15, 2021 15 hours ago, Netduma Fraser said: Are there any settings you changed specifically on the XR500 that you have yet to put in the XR1000 or are you using the exact same settings? No. they are the same I do only the bridging on one lan port. I tested all ports they are suffering from the same problem
Administrators Netduma Fraser Posted February 15, 2021 Administrators Posted February 15, 2021 Okay I think I'll need to forward this onto Netgear as it is one of their features, I'll get back to you when I have any more information.
Administrators Netduma Fraser Posted March 2, 2021 Administrators Posted March 2, 2021 I've received a response from Netgear, could you try this please? Enable VLAN/Bridge Setup in "VLAN/Bridge Settings" page. Select "By bridge group" and then select "Port4" Apply. Wait 2 minutes until GUI back. Connect IPTV to LAN port 4 ( near USB ). It is bridge mode. IPTV will get IP from WAN side DHCP server. See if this IPTV can access the internet without any issues.
