Help with DumaOS
Lolis
everytime I try to open my DumaOS by writing the IP adress in the book I get the message "this site cant be reached, the connection was reset". When I go to reset my router It doesnt do anything and im holding the reset button for 40 secs
You may not see any physical indications that the R2 is resetting, but it will be, it usually takes around 5 minutes to reset.
Are you able to access the interface by going to dumaos/ instead?
how would I go to dumaos instead? isnt the only way to put the IP that is on the book?
There are two ways, you can either enter '192.168.77.1' in your browser, or you can enter 'dumaos/' in your browser (be sure to remember to forward slash) :)
I still cant access the dumaos either way, says the site cant be reached
How are you connected to the router currently via ethernet or via WiFi? Can you access if you're connected to one of those methods over the other?
On your PC open command prompt and type ipconfig and press enter. Then post the results here please.
