Power Issues
Sorry to hear you're having this issue. When did this occur? Is it the first time you're powering on the router after you received it? Did it happen randomly?
Have you tried connecting it to a different power outlet? If you have and it still doesn't work do you have a spare power adapter of similar voltage to see if that works?
Hello Netduma Fraser
I was playing WarZone and got kicked off the game lost connection I troubleshooted and saw the NetDUMA R2 wasn't powered on. I've connect it to another outlet still no power. It seem like its a short in the power adapter slot.
7 hours ago, Tony Cortez Williams said:
I tried using one from my MIDI keyboard and that solved the issue.
That's great to hear! Consider emailing us [email protected] and they may be able to send you a replacement adapter.
Great! As the issue has been resolved I'll close the topic, feel free to open another if needed and we'll be happy to help!
