Happy new years fellow DUMA's, i got my son a pc for Christmas but i have 1 small problem. his bedroom is about 60 feet away from the R2 router, anyone got any recommendations on brand and size? Hopefully you guys can point me in the right direction on a good cable / cost and should i do 60feet 75feet or 80? what ever is the better value but performance is top priority. thank you in advance for pointing me in the right direction. Cheers mates
you could move the cable connection to his room but your isp will charge for that, and he will have the modem and the router in his room. having a long ethernet is better than wifi but not as good as having a 6ft ethernet cable to his pc/console. as of brand i have no clue besides that cat6 is better than cat5e and cat5 in terms of wiring because it can handle up to 1000mbps or 1gbps, so maybe ill learn about it here.
lol not a option, the router is on my desk about 2 feet away from my xbox so relocating it is not a option, why i asked for a cable recommendation, thank you, i have a 1 gigabit connection so i think i need cat8
Why cat 8? As long as you have the right cable standards and if shielding is required you may need an earthing point a Cat6 is more than enough for the R2. You will gain no advantage with a cable that is over spec even a cat 5e would do the job under normal running conditions and you would not notice any difference.
I use Cat 6 STP and it’s fine and a total over kill for my setup.
what cable would recommend? i have a regular cat 6 insignia ethernet cable.
2 minutes ago, Newfie said:
Belden or I have some non fancy Belkin. I don’t like flat cables myself. If your cables working and you have no issues it’s fine.
i want top performance not just working lol
You will never tell a difference, trust me I’m fussy and as long as it’s from a known company it will be fine. Not saying all those cables you see on Amazon from Tom, Dick, and Harry are bad it’s I just prefer a known company.
ok thank you
40 minutes ago, TODDzillaInLA said:
From what I see cat8 is the new slandered so why not get a cable I’ll probably never have to replace
https://www.google.com/amp/s/www.tomsguide.com/amp/reference/ethernet-cables-explained
Newfie can you post a link to a belden cable 60 to 80 feet nothing pops up on Amazon under that brand
I’m U.K. so RS components are my supplier. Not sure about US suppliers.
  • 2 years later...
5 hours ago, mildredlopez said:
Thinking of hardwiring my Marantz streamer. Does anyone have experience with Morrow Ethernet cables? I have and like their other cables. If not, any recommendations for cables under $200? Thx in advance. MPO Cable
i ended up getting this one from amazon
Amazon.com: GLANICS CAT 8 Ethernet Cable, 75 ftInternet Cable with RJ45 Connector, Outdoor&Indoor for Network Switches, Routers, Gaming, Modems, Network Adapters, PS5, PS4, PC, Laptop, Desktop (Blue) : Electronics
