Hybrid VPN protocol UDP issue
ifell
I'm having some trouble with the Hybrid VPN, i use PureVPN. each time i try and connect to any server using ( Protocol UDP ) it gets stuck in a loop displaying Connecting... and doesn't actually connect. it  was working up until i had to swap my modem out because the modem died, here's what comes up in the log:
Thu Dec 31 13:25:01 2020 OpenVPN 2.4.7 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Thu Dec 31 13:25:01 2020 library versions: OpenSSL 1.0.2p  14 Aug 2018, LZO 2.10
Thu Dec 31 13:25:01 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:25:01 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:25:02 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:25:02 2020 UDP link local: (not bound)
Thu Dec 31 13:25:02 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:26:02 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:26:02 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:26:02 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:26:07 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:26:07 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:26:07 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:26:07 2020 UDP link local: (not bound)
Thu Dec 31 13:26:07 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:27:07 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:27:07 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:27:07 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:27:12 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:27:12 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:27:12 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:27:12 2020 UDP link local: (not bound)
Thu Dec 31 13:27:12 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:28:12 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:28:12 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:28:12 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:28:17 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:28:17 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:28:17 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:28:17 2020 UDP link local: (not bound)
Thu Dec 31 13:28:17 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:29:17 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:29:17 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:29:17 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:29:22 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:29:22 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:29:22 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:29:22 2020 UDP link local: (not bound)
Thu Dec 31 13:29:22 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:30:22 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:30:22 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:30:22 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:30:32 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:30:32 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:30:32 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:30:32 2020 UDP link local: (not bound)
Thu Dec 31 13:30:32 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:31:32 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:31:32 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:31:32 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:31:52 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:31:52 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:31:52 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:31:52 2020 UDP link local: (not bound)
Thu Dec 31 13:31:52 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:32:52 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:32:52 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:32:52 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:33:32 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:33:32 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:33:32 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:33:32 2020 UDP link local: (not bound)
Thu Dec 31 13:33:32 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:34:33 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:34:33 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:34:33 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:35:53 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:35:53 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:35:53 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:35:53 2020 UDP link local: (not bound)
Thu Dec 31 13:35:53 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:36:53 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:36:53 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:36:53 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:39:33 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:39:33 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:39:33 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:39:33 2020 UDP link local: (not bound)
Thu Dec 31 13:39:33 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:40:33 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:40:33 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:40:33 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:45:33 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:45:33 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:45:33 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:45:33 2020 UDP link local: (not bound)
Thu Dec 31 13:45:33 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:46:33 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:46:33 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:46:33 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Dec 31 13:51:33 2020 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Dec 31 13:51:33 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Dec 31 13:51:33 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]192.253.241.2:53
Thu Dec 31 13:51:33 2020 UDP link local: (not bound)
Thu Dec 31 13:51:33 2020 UDP link remote: [AF_INET]192.253.241.2:53
Thu Dec 31 13:52:33 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Dec 31 13:52:33 2020 TLS Error: TLS handshake failed
Thu Dec 31 13:52:33 2020 SIGUSR1[soft,tls-error] received, process restarting
Are using the basic setup as in selecting a server from the list or have you added a PureVPN OpenVPN configuration file? You specified UDP so does that mean you've tried TCP and it works?
used basic setup only. TCP works but i need UDP to work. i have not used a config file
Okay so we'll likely need to update the UDP files then. It doesn't matter which you use to be honest as that's just how the tunnel connects - UDP and TCP will still be going through the VPN.
A key difference between TCP and UDP is speed, as TCP is comparatively slower than UDP. Overall, UDP is a much faster, simpler, and efficient protocol, however, retransmission of lost data packets is only possible with TCP. watching netflix has been challenging with TCP, when UDP was working i had no trouble at all. with TCP loading videos on netflix takes much longer and get caught in a loop of loading and buffering, making movies unwatchable
We'll need to update the configurations so in the meantime you'll need to obtain the config from PureVPN and then you can enter it into the VPN feature and connect via UDP.
