Jettman Posted December 29, 2020 Posted December 29, 2020 hey guys whats the best ethernet cable to buy?
Administrators Netduma Fraser Posted December 29, 2020 Administrators Posted December 29, 2020 There isn't necessarily a best cable to buy, as long as you get the correct Cat for your speeds then it will be fine. If you have any potential interference in your home then a shield cable would be better.
II N3MES1S II Posted December 29, 2020 Posted December 29, 2020 cat6, cat7 or maybe cat8? I use cat7 by Ugreen from amazon
