Xr700 lan port problem
I’m only receiving internet signal from the wifi, anything connected to the lan ports have no internet connection. What could be wrong? I have tried a router reset from the web interface and from the reset button on the back of the xr700 to no avail. Please help.
Did you just get this XR700? Has it ever worked on any of the LAN ports?  I must say I find it strange that none of them are working.. Specially if you have done a few factory resets..  When you are connected to a LAN port are you able to connect to the interface of the XR700? Like log into DumaOS on the router?  Hopefully Netduma will be able to give you a few things to try.. Im at a loss on this one..
Good luck!
Zippy.
Okay thats good news at least it was working.. Give your idea a try.. If not report back here.. Im sure @Netduma Fraser might have some good advice for you.. He should be back on tomorrow..
Thanks!
Zippy.
Guest
