need VPN help
What VPN provider do you have a subscription with? Is it PureVPN or HMA or did you add the OpenVPN Config manually? If the latter can you provide the config file please? Does it show that it's connected or disconnected?
  • 3 months later...
Hi, I am also having issues with using a VPN. I am using PureVPN and it shows that everything is connected on the router page, but my devices are not actually having the IP change. Any suggestions?
Have you added your devices to Hybrid VPN and selected Do NOT VPN these services?
Hi, Yes I have. If I use the desktop app it works ( only on desktop obviously) but once I try to set it up on the router it just doesn't work.
Hi, I have now also tried with ExpressVPN to test if it was an issue with PureVPN but the same issue occurs.
