daz Posted November 24, 2020 Author Posted November 24, 2020 23 minutes ago, Netduma Fraser said: Email [email protected] and request a replacement would be my advice at this point as everything has been tried and so otherwise you'd have to wait for a new version. ok emailed
Renan Posted November 24, 2020 Posted November 24, 2020 6 hours ago, Netduma Fraser said: No firmware at the moment but we are testing one. What is the R2 connected to exactly? Is it a pure modem (no WiFi) or a modem/router? ISP Modem(Bridge Mode) -> R2(dhcp wan ip)-> devices(Wifi)
Administrators Netduma Fraser Posted November 24, 2020 Administrators Posted November 24, 2020 17 minutes ago, Renan said: ISP Modem(Bridge Mode) -> R2(dhcp wan ip)-> devices(Wifi) Okay on the ISP modem, take it out of bridge mode please and apply a static/reserved IP address for the R2 (the same one will be fine). Then input that into the ISP router DMZ function. Then disable the ISP router WiFi and UPnP and see if that keeps you online.
Rev Posted November 30, 2020 Posted November 30, 2020 On 11/24/2020 at 4:01 PM, Netduma Fraser said: Okay on the ISP modem, take it out of bridge mode please and apply a static/reserved IP address for the R2 (the same one will be fine). Then input that into the ISP router DMZ function. Then disable the ISP router WiFi and UPnP and see if that keeps you online. I'm going to try this as well, it's very frustrating to lose the connection multiple times a day.
Administrators Netduma Fraser Posted November 30, 2020 Administrators Posted November 30, 2020 28 minutes ago, Rev said: I'm going to try this as well, it's very frustrating to lose the connection multiple times a day. Please provide as much information as you can here: https://forum.netduma.com/topic/33667-having-disconnect-issues-please-post-here/
