Ezy Ms Posted October 10, 2020 Posted October 10, 2020 Hi, I previously had problems with netduma r1 because of slow speed when I had way more speed. I have changed house since then and can only get 10 down and 1 up. Is r2 still worth it or it's pointless? Thank you
Administrators Netduma Fraser Posted October 10, 2020 Administrators Posted October 10, 2020 Well the R2 does have AC WiFi but with those speeds it isn't needed and you'll be able to reach your full speeds with the R1. I have given you access to the R1 beta so you can try out 3.0 https://forum.netduma.com/forum/130-dumaos-30-beta-netduma-r1/
Ezy Ms Posted October 10, 2020 Author Posted October 10, 2020 So I can still take advantage of duma 3.0 features with that speed?
Administrators Netduma Fraser Posted October 10, 2020 Administrators Posted October 10, 2020 Yes of course! No speed requirement for any of the features.
Ezy Ms Posted October 10, 2020 Author Posted October 10, 2020 19 minutes ago, Netduma Fraser said: Yes of course! No speed requirement for any of the features. Thank you.
