bowser914 Posted October 9, 2020 Posted October 9, 2020 I don't know where to start with this router. It constantly drops signal, I will all of a sudden be connected via ethernet with no internet. It also likes to all of a sudden stop my wifi speeds. Even with everything disabled. Here are some examples here are two pics, one with R2 connected and one without: normal.jfifslow.jfif
Avalon2099 Posted October 9, 2020 Posted October 9, 2020 You are not alone, man. This thing has caused me nothing but headaches since I got it.
JoeGantic Posted October 10, 2020 Posted October 10, 2020 Same here unfortunately. Constant device drops, interrupted data streams and many, many reboots. I haven't complained since the fix was supposed to be coming but a month of this is asking for alot of patience... JoeGantic
bowser914 Posted October 10, 2020 Author Posted October 10, 2020 I mean I got to the point where I turned off every "advantage" this router is supposed to give because it just messes with everything. I know it is a newly released device but the bare minimum I expect from a router is that it will allow me to use the internet normally...
Administrators Netduma Fraser Posted October 10, 2020 Administrators Posted October 10, 2020 Sorry to hear you're having this issue. I've sent you a PM, please see if that helps with the issues.
Deprave Posted October 10, 2020 Posted October 10, 2020 I’ve been having the same issues as well. I have updated mine but even with that update it’s still acting weird. I started to lag a lot and I thought it was the VPN. I turned the VPN off and rebooted the R2. Loaded it back up and the apps weren’t working giving me problems so I just unplugged my R2 and plugged in my XR700 😂 no problems. I was pissed for like 2 minutes then got over it lol. Not going to use it until the Official firmware update 🥴
Administrators Netduma Fraser Posted October 10, 2020 Administrators Posted October 10, 2020 24 minutes ago, deprave said: I’ve been having the same issues as well. I have updated mine but even with that update it’s still acting weird. I started to lag a lot and I thought it was the VPN. I turned the VPN off and rebooted the R2. Loaded it back up and the apps weren’t working giving me problems so I just unplugged my R2 and plugged in my XR700 😂 no problems. I was pissed for like 2 minutes then got over it lol. Not going to use it until the Official firmware update 🥴 I've sent you a more up to date one if you want to try it.
