hello big problem on netduma R2
julienFR
I was playing yesterday and suddenly I heard a poof the router is off no more way to do whatever I unplugged then plugged in again the same it was hot I have to make a return for repair or exchange
It made that noise and then suddenly internet access got cut off? If you have left it unplugged for awhile and then plug it in again do you see lights appear on the router?
Guest Killhippie
is the router running hot all the time
yes it happens suddenly with a noise like a pff no led I unplug everything afteris the router running hot all the time
the router has 3 days it only happened once I was so disappointed that I switched to the xr500 lol more seriously I would test tomorrow if it decides to turn back on in any case for new equipment it is abused made more than quality control at the assembly finally this is only my opinion
I'm going to try to power it on nothing no led lights up the one done since yesterday that it was off it looked dead to me
Guest Killhippie
Can you not type with such a large font please it makes it harder to read as people need to scroll :)
Let us know if it powers on, it may be you need to try another power adapter with the same voltage. If it still doesn't work please email [email protected] with your order number and a link to this topic.
i might sound stupid but i don't know how to change it
Guest Killhippie
You just did  :)
