How to find best settings for QOS Congestion control ?
DavidCellz
I am trying to get the best out of my r2. I would like to know how to set my sliders for the QOS based on my speeds . I usually get 300 downloads and 23 uploads. I currently have the default 70% for both and would like some tips on how to better use it. And how can I test these percentages when I change them ? Should I aim for A+ in the connection tests ?
Thank you in advance
Once I did the Auto Setup in QoS congestion control and used the recommended settings, my Connection test has given me B Ping and A+ Ping under load. I couldn't find an ideal % by trial and error and this worked for me. Just fyi
You can either try the above suggestion although it sometimes suggests a very aggressive setting - we're working to improve that.
Otherwise you can try different percentages then do a connection benchmark test and look at the Ping Under Load results - rinse, repeat until you find the percentages that lower the results as much as possible.
Thanks ! I also have one more question. I play Modern Warfare GameBattles that has its own servers . It’s not P2P connection . Would I have to go into spectating mode on my geofilter to join the lobby ?
Yes I would recommend you do that - as it is a predetermined match you don't want to block it.
