Albo2001 Posted September 9, 2020 Posted September 9, 2020 Hi Guys , if i unticked share excess and set upload speed to 1% the speed remain to maximum! Download speed works well , the problem is upload.. thanks
Administrators Netduma Fraser Posted September 9, 2020 Administrators Posted September 9, 2020 Could you post in the XR500 beta forum on the Netgear Community site please and answer these questions there: Did you untick share excess when you were looking at download or upload as there is a separate option for each. Also have you got any manual traffic prioritization settings? Are you using PPPoE, IPv6 or VLAN?
Administrators Netduma Fraser Posted September 10, 2020 Administrators Posted September 10, 2020 7 hours ago, Albo2001 said: Vlan tagging Fraser.. Okay thank you, please post over on the beta forum.
TheAspergerGamer Posted September 11, 2020 Posted September 11, 2020 15 hours ago, Netduma Fraser said: Okay thank you, please post over on the beta forum. Just a quick one, so I do not make another thread only for this question. Is the download link for the BETA still down, as per Alex's update here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/REDACTED-New-firmware-XR500-V2-3-2-104-DumaOS3-0-Beta/m-p/1973365#M1019 ?
Newfoundland Posted September 11, 2020 Posted September 11, 2020 7 minutes ago, TheAspergerGamer said: Just a quick one, so I do not make another thread only for this question. Is the download link for the BETA still down, as per Alex's update here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/REDACTED-New-firmware-XR500-V2-3-2-104-DumaOS3-0-Beta/m-p/1973365#M1019 ? Yes, if you keep an eye on the beta forum when a new firmware is released it will pop up there.
TheAspergerGamer Posted September 11, 2020 Posted September 11, 2020 Just now, Newfie said: Yes, if you keep an eye on the beta forum when a new firmware is released it will pop up there. Thank you!
