Nigel Posted September 3, 2020 Posted September 3, 2020 When I run the auto setup for the congestion control, it goes through the cycle but does not save the settings when finished. Is there anything you can do thanks.
Administrators Netduma Fraser Posted September 3, 2020 Administrators Posted September 3, 2020 What do mean it doesn't save it? There is an option at the bottom for you to click save settings, do you have that available?
R3my7 Posted September 5, 2020 Posted September 5, 2020 On 9/3/2020 at 4:00 PM, Netduma Fraser said: What do mean it doesn't save it? There is an option at the bottom for you to click save settings, do you have that available? Whenever I run my auto setup. I have the screen pop up that runs the test, but I can't find save settings anywhere.
Nigel Posted September 5, 2020 Author Posted September 5, 2020 The save setting is there it just when you press save it does nothing
Guest Killhippie Posted September 5, 2020 Posted September 5, 2020 7 hours ago, Nigel said: The save setting is there it just when you press save it does nothing Did you do a factory reset and clear your bowser cache? Try the browser cache first, if not do a factory reset and start again.
Administrators Netduma Fraser Posted September 5, 2020 Administrators Posted September 5, 2020 15 hours ago, R3my7 said: Whenever I run my auto setup. I have the screen pop up that runs the test, but I can't find save settings anywhere. Use the browser zoom to zoom out slightly, do you then see it? This should be fixed in a future firmware. 9 hours ago, Nigel said: The save setting is there it just when you press save it does nothing As above try that and let us know if it works.
Nigel Posted September 5, 2020 Author Posted September 5, 2020 I can see the "save settings" button but when I press it it does not save the setting that the auto setting result lands on
Administrators Netduma Fraser Posted September 5, 2020 Administrators Posted September 5, 2020 18 minutes ago, Nigel said: I can see the "save settings" button but when I press it it does not save the setting that the auto setting result lands on Is this after clearing the web browser cache/cookies? What firmware version are you on and what web browser/device are you using to access it?
