congestion control issues!!!
Tac toby
So I am trying to select the auto setup feature prioritization ping , and when it says testing it will not give me the option to save my Stephen and it always has my download settings negative.
note: no save button and no percentage
For the Save Settings button to appear you'll need to use the zoom out function on your browser - this is fixed in a later firmware. We've got a fix in this firmware that will prevent it from going below 1%. We're continuing to improve upon the feature but it's only a suggestion so you can still manually change the percentages to whatever you like.
https://www.dropbox.com/s/vklzjkftpdcd01t/DumaOS-R2-RC5-Production-3.0.129-100820.sig?dl=0
To update: Download the file above, open DumaOS, click the three dots in the top right corner, choose update, upload the file you just downloaded, and wait a few minutes while the R2 restarts.
okay thank you, the picture it doesn't have I number for the download and i keep getting that
