Connection help
Aaronlogan
I’ve connected and bridge my isp modem and I’ve gone threw all the set up for the r2 but I can’t seem to get my wired Xbox to work
Hey welcome to the forum.. Are other devices able to connect just fine? And is your xbox the only wired device connected to the R2?
Thanks!
Zippy.
What is slow and in what way? Are you referring to the interface or the console? If the console do you mean the speeds it reports?
I’m still trying to figure out the things on the router to find better lobbies so far I kind of have better lobbies but they only lasted for a couple games and went back to the lag I usto get. I haven’t set anything up really yet in the router
Are you using QoS and the Geo-Filter? Where are you located roughly? What is your average ping to the game as shown by the Geo-Filter?
I think I’m using both yeah. I’m from Canada my girlfriend was finding under 30 ping lobbies but my profile was only finding like 100ping
Are any devices connected to the ISP modem/router? Could you provide a screenshot of your QoS and Geo-Filter settings please? For the Geo-Filter take the screenshot when you're in a game so we can see the ping. Are you located in the same place where that ping difference occurs?
Yes there’s cable boxes On the isp modem that can’t be moved to the new router. She is on the the same console as me. I can get a picture when I play
Yes please provide pictures of the QoS page, Geo-Filter page when your girlfriend gets the low ping and one where you get the high ping.
