Administrators Netduma Fraser Posted August 13, 2020 Administrators Posted August 13, 2020 Good suggestions from Newfie here!
al1manu7 Posted August 13, 2020 Author Posted August 13, 2020 2 hours ago, Newfie said: Worth a go but is the XR500 new. If it is check it’s updated to latest firmware and then do a factory reset using the rear pin hole method at the back. This will help clear low level code. set up again and test. the XR500 is about a month old. Done a factory reset anyway and still get around 400-500 wired. will wait for the cable tomorrow and update. appreciate the help so far
al1manu7 Posted August 15, 2020 Author Posted August 15, 2020 On 8/13/2020 at 9:25 PM, al1manu7 said: the XR500 is about a month old. Done a factory reset anyway and still get around 400-500 wired. will wait for the cable tomorrow and update. appreciate the help so far Update - i think something was up with virgin when i was doing speedtests. later on the speeds picked up and havent dropped since then. Appreciate the help!
