Wireless - no internet connection
wrighty338
I also tried a factory reset with no luck… I can’t use Wi-Fi on my iPhones
  • Replies 53
It use to work fine, I didn’t change any setting and suddenly it stops working
I solved changing channels on both 2.4 and 5 GHz to 1 and 36, then disabling Wi-Fi and rebooting the router. At startup I  enabled again Wi-Fi and it worked
Glad to hear you were able to resolve the issue. I would recommend disabling the Private Addresses options on the iPhones for the R2 network as that can cause some issues so should hopefully prevent that happening in future with it disabled.
