liveandletdie34 Posted July 13, 2020 Posted July 13, 2020 Hi any of you play mw on pc. I have encountered an issue at least for me as when I have the R1 app open the proformance of game play is what seems laggy and or mouse delay just not smooth at all. Once I close it it’s fine any idea
Administrators Netduma Fraser Posted July 14, 2020 Administrators Posted July 14, 2020 I imagine this is more likely the web browser using CPU etc and when closing it the game improves. To check can you reproduce it if you're watching a YouTube video while playing for example? If you're using Google Chrome its known that it is a massive resource hog.
liveandletdie34 Posted July 15, 2020 Author Posted July 15, 2020 22 hours ago, Netduma Fraser said: I imagine this is more likely the web browser using CPU etc and when closing it the game improves. To check can you reproduce it if you're watching a YouTube video while playing for example? If you're using Google Chrome its known that it is a massive resource hog. 22 hours ago, Netduma Fraser said: I imagine this is more likely the web browser using CPU etc and when closing it the game improves. To check can you reproduce it if you're watching a YouTube video while playing for example? If you're using Google Chrome its known that it is a massive resource hog. I will give it ago later on. And yes I always use chrome. Do you advise on something better
liveandletdie34 Posted July 15, 2020 Author Posted July 15, 2020 Been getting this error to not sure if it means anything but not seen it before and I have had the r1 for a few year now
Administrators Netduma Fraser Posted July 15, 2020 Administrators Posted July 15, 2020 Chrome is what I would recommend. Can you reproduce that error frequently? If not and it hasn't caused any issues then you can ignore it.
