abr_wz Posted June 29, 2020 Posted June 29, 2020 Hello, I have bought the Netgear XR500 last week and I am facing some issues regarding "connections" between devices on Wifi 2,4Ghz, Wifi 5Ghz and Ethernet. - I can't use my Chromecast (connected on wifi 2,4Ghz) with my Smartphones (connected on wifi 5Ghz) - I can't access to my computer (SMB) (connected on Ethernet) with my Oculus (connected on wifi 5Ghz) It seems there is a Wifi isolation issue. Firmware version : V2.3.2.56 Using "Orange France DHCP " profil I am not using guest wifi. I think it is a known issue (but i am not sure) , but is it planned to have a correction ?
Administrators Netduma Fraser Posted June 29, 2020 Administrators Posted June 29, 2020 Hey, welcome to the forum! Yes this is something that is coming to light as an issue, if they're both using 2.4GHz for example does it work at all? Try disabling QoS fully and in WAN Settings toggling IGMP Proxying and make sure respond to ping is on - unlikely to fix but just making sure.
abr_wz Posted June 29, 2020 Author Posted June 29, 2020 Hi, thanks for the quick answer. Chromecast (2,4Ghz) - Smartphone (2,4Ghz) : OK Chromecast (2,4Ghz) - Smartphone (5Ghz) : KO Oculus (2,4Ghz) - PC (Ethernet) : KO Oculus (5Ghz) - PC (Ethernet) : KO Still have the issue with : Disabling QOS, toggling IGMP proxying and ping conf Do you know if this defect is planned to be corrected in a futur release ?
Administrators Netduma Fraser Posted June 29, 2020 Administrators Posted June 29, 2020 Could you try setting up and using the guest network and enable allow guests to see each other and the local network and see if that works please? We will try to get this fixed for 3.0 yes.
abr_wz Posted June 30, 2020 Author Posted June 30, 2020 All combinations are KO Tests results : Guest wifi 2,4Ghz (chromecast) <-> Private Wifi 2,4Ghz (smartphone) : KO Guest wifi 2,4Ghz <-> Guest Wifi 5Ghz : KO Guest wifi 2,4Ghz <-> Private Wifi 5Ghz : KO Guest wifi 5Ghz (oculus) <-> Ethernet (PC) : KO
Administrators Netduma Fraser Posted June 30, 2020 Administrators Posted June 30, 2020 That's disappointing, there is nothing I can really suggest settings wise I don't think that could help. You could try making a ticket directly with Netgear as they may have more suggestions: http://support.netgear.com/
abr_wz Posted July 1, 2020 Author Posted July 1, 2020 Ok, thanks, i am currently dealing with netgear support (the road will be long... they asking me to put the XR500 in AP mode ) During my tests, I have notice that ping is OK between devices in differents wifi "band". Does it means there are something like TCP filtering in this issue ?
Administrators Netduma Fraser Posted July 1, 2020 Administrators Posted July 1, 2020 Yikes okay, kind of misses the point there with AP mode! I have let our team about this as well in case they have any ideas/can make sure to look out for it in 3.0. That would be my understanding that something is interfering with the packets unnecessarily.
abr_wz Posted July 2, 2020 Author Posted July 2, 2020 For info, in AP mode, there is no wifi isolation, devices connected in different wifi bands can communicate but I can't stay in AP mode, I lose all interest in this router. Do you think I can test DumaOS 3.0 bêta in order to check if it's different before to return my product and refund ?
Administrators Netduma Fraser Posted July 2, 2020 Administrators Posted July 2, 2020 Exactly, the purpose of the router would be lost. Netgear decide on who/when to invite testers so I can't accelerate this unfortunately. How long do you have before the time window closes? They're inviting more people all the time so there is a chance you'll get it before that.
Administrators Netduma Fraser Posted July 2, 2020 Administrators Posted July 2, 2020 Try and hold off for as long as possible if you can to see if you can get in the beta.
