Eefo Posted May 25, 2020 Posted May 25, 2020 Is there a way to fix this issue where my Tv is taking most of the bandwidth rather than my playstation which i've allocated more?
Administrators Netduma Fraser Posted May 26, 2020 Administrators Posted May 26, 2020 If you disable Share Excess for download on Bandwidth Allocation then this will cap all the devices to the allocations that you have set, this may affect other devices if they need more bandwidth than has been allocated though. Your best bet is to use Anti-Bufferbloat to prevent devices causing others to lag, then everything can use the internet as normal.
