Best settings for WZ on PC XR700
Argsint
What are the best settings for warzone got the XR700 and getting so many laggy servers. The settings I got now is that I have my PC as an gaming console and implemented call of duty settings in GEO filter but yesterday my open NAT become Moderate for no reason... Haven't change anything tho. I am on EU servers living in (Sweden)
What is the average ping you're getting on the Geo-Filter? Have you used port forwarding to open the NAT at all? I'd suggest trying to force different servers to see if that gives a better experience, the ones you're playing on may be under heavy load.
Why did I have open NAT like two days ago but not now? I have never have to open any ports to get open NAT. Should I change from console to pc again?
Has anything changed between then and now? Are you just using the ISP hub in modem mode/XR in DMZ and UPnP on the XR? I don't think it will be necessary to change platform. The Geo-Filter can sometimes cause a misreading, if you switch to spectating mode does it change to open?
It is back to open again today... havent changed anything but how do i setup the geo filter to work properly? i got my pc set to console or?
That's really strange! In the Device Manager change the PC to have the device type of a PlayStation or Xbox and then add it back to the Geo-Filter.
That's how I have done. But it looks so strange are you just supposed to se the servers or do you see all the players to?
What do you mean it looks strange? It is a server based game so you would only see the server, not the players.
