Spot the problem!
In all seriousness, I made a complaint about this 8 months ago and it's still not had an update. Should I be complaining to Netgear instead?
Oh the router also lets people connect who have a Triangle over their marker on the map. Please dear god fix this stuff already.
The problem is you have fast search enabled which gets you a game faster but can result in games outside of your PA limit. If they show with a triangle then you have blocked them but if you're playing a game that uses dedicated servers then you can't dictate who can join that server, just what server you connect to.
This helped actually, thanks much, but doesn't excuse that it properly listed it as blocked but was still connected to me. Also the games in question are peer 2 peer. Specifically fighting games like Tekken 7 and Granblue Fantasy VS.
How do you know someone with a triangle is directly connected to you and also not connected to a server? In the picture you've shown there are two hosts that have been allowed there, one is probably a server and the other a peer.
