PS4 Hybrid VPN Connection Issues
I have an XR500 using HideMyAss vpn.  This has been working great until Friday.  I only have my 2 PS4's in the HybridVpn.  I can enable and connect to the VPN no problem.  However when I try to login to a game on PS4 I can not connect.  This is the first time I have had this issue.  I have tried both wireless and wired connections and get the same problem.  If I turn off the VPN I am able to login and play games no problem.  I am running the latest firmware on PS4 and XR500.  Please help me resolve this.
Thanks
After trying numerous things to fix this issue the only way I have found to resolve it is to remove the PS4 from HybridVpn devices.  Load into game and enable VPN the add the PS4 back to the HybridVPN devices. Log out of game and then it will let me log in the game.  I shouldnt have to do all of these steps to use the HybridVPN function.  Also I have power cycled the router with the 30-30-30 method and this does not help.  Any suggestion on how to get this to work correctly?
What game does this happen on and does it occur on all games you try to play? Are you using the Geo-Filter at the same time?
Thanks for the response.  No I do not have the Geo-filter enabled.  It is occurring on every game.  I did a speed test on my PC while having the VPN active through HMA desktop app and my speeds were ok.  When I added my PC to the Hybrid VPN devices on the router and ran a speed test they were terrible.  And no I did not have the desktop vpn open as well as the router vpn active at the same time.  I really need to get this figured out since it is the main reason I purchased the router was to use the Hybrid VPN feature.
42 minutes ago, Netduma Fraser said:
What ping do you have when using the VPN? Where are you located and what VPN server are you connecting to?
This is the speed I am getting.  I have 1GB fiber so this is a little extreme even for a VPN
Yes I tested that on PC through the Hybrid VPN. The ping was over 100 ms.  If I use VPN through the desktop app I was getting 56 Mbps down & 18 Mbps upload.  So there is something with the HybridVPN on the router that is slowing down the speeds substantially.  I am logged in correctly to my VPN account and get a connected confirmation on the screen.  I am using TCP.  I have tried UDP and was getting the same slow connection
Due to the technology that Hybrid-VPN uses, we'd expect it to go a little slower than the desktop app, as the desktop app is customised for that specific VPN service. Hybrid-VPN is more generic, it uses the OpenVPN protocol.
The ping does seem very high, are you using the same server on both the desktop version and hybrid VPN? Are you getting a reasonable ping on the desktop version?
I am using the same server on HybridVPN and Desktop app.  Yes I am getting a reasonable ping on the desktop version.  The HybridVPN should not slow my connection from 56 mbps to 1 mbps.  That is completely unusable.  The HybridVpn is the main reason I purchased this router so I could select which devices I wanted to add to my VPN and not have to put my entire network on the VPN if I wanted to enable it.  I have friends that use OpenVPN protocol on their routers and are not getting abysmal speeds that I am getting.  There has got to be some fix for this or I am going to have to return the router because it is unusable in its current state
In relation to you, how far away is the server that you are connecting to? As that will impact both the speed and ping you're able to get through the router. It's also possible that the HMA servers have been banned by the games, have you tried with another VPN provider to see if it works through their servers?
The nearest server I am connecting to is 300 miles away. I have not tried another VPN provider.  I purchased the HMA VPN service because that is what is pre-configured in the Hybrid VPN.  I have also tried different servers in the US as well as Cuba, London and other areas and get the same result using the Hybrid VPN feature.  I dont want to purchase another VPN as I have already paid for HMA
If you don't use the preconfigured files and instead download them and add using the advanced section and choose the closest server to you do you see a difference?
I will try and see if that helps.  That defeats the entire purpose of the easy hybrid vpn feature which is why i purchased this router.
I did the advanced setup and got the same result.  Super slow speeds. This only happens when the VPN is activated through the router not when using desktop client
How are you connecting to the VPN? - Are you using TCP or UDP? It shouldn't in theory make a difference but if you're not already then use TCP. Could you also provide the config you're using and I'll see if there is a way to speed it up.
I have tried both TCP and UDP with no success. I will email you the config file
Could you try this file please and see if there is any change:
client
auth-user-pass
proto tcp
ping-exit 70
remote bw.hma.rocks 8443
dev tun
nobind
persist-key
persist-tun
ns-cert-type server
verb 3
route-metric 1
comp-lzo yes
comp-noadapt
cipher AES-256-CBC
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
<cert>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</cert>
<key>
-----BEGIN RSA PRIVATE KEY-----
MIIEpAIBAAKCAQEA5XY3ERJYWs/YIeBoybivNlu+M32rJs+CAZsh7BnnetTxytI4
ngsMRoqXETuis8udp2hsqEHsglLR9tlk9C8yCuKhxbkpdrXFWdISmUq5sa7/wqg/
zJF1AZm5Jy0oHNyTHfG6XW61I/h9IN5dmcR9YLir8DVDBNllbtt0z+DnvOhYJOqC
30ENahWkTmNKl1cT7EBrR5slddiBJleAb08z77pwsD310e6jWTBySsBcPy+xu/Jj
2QgVil/3mstZZDI+noFzs3SkTFBkha/lNTP7NODBQ6m39iaJxz6ZR1xE3v7XU0H5
WnpZIcQ2+kmu5Krk2y1GYMKL+9oaotXFPz9v+QIDAQABAoIBAQCcMcssOMOiFWc3
MC3EWo4SP4MKQ9n0Uj5Z34LI151FdJyehlj54+VYQ1Cv71tCbjED2sZUBoP69mts
T/EzcsjqtfiOwgrifrs2+BOm+0HKHKiGlcbP9peiHkT10PxEITWXpYtJvGlbcfOj
Ixqt6B28cBjCK09ShrVQL9ylAKBearRRUacszppntMNTMtN/uG48ZR9Wm+xAczIm
dG6CrG5sLI/++JwM5PDChLvn5JgMGyOfQZdjNe1oSOVLmqFeG5uu/FS4oMon9+Ht
fjHJr4ZgA1yQ2wQh3GvEjlP8zwHxEpRJYbxpj6ZbjHZJ2HLX/Gcd9/cXiN8+fQ2z
PIYQyG9dAoGBAPUUmt2nJNvl7gj0GbZZ3XR9o+hvj7bJ74W2NhMrw6kjrrzHTAUQ
d1sBQS8szAQCLqf2ou1aw9AMMBdsLAHydXxvbH7IBAla7rKr23iethtSfjhTNSgQ
LJHVZlNHfp3hzNtCQZ7j0qVjrteNotrdVF7kKPHDXAK00ICy6SPNjvrXAoGBAO+v
dnO15jLeZbbi3lQNS4r8oCadyqyX7ouKE6MtKNhiPsNPGqHKiGcKs/+QylVgYvSm
m7TgpsCAiEYeLSPT+Yq3y7HtwVpULlpfAhEJXmvn/6hGpOizx1WNGWhw7nHPWPDz
f+jqCGzHdhK0aEZR3MZZQ+U+uKfGiJ8vrvgB7eGvAoGAWxxp5nU48rcsIw/8bxpB
hgkfYk33M5EnBqKSv9XJS5wEXhIJZOiWNrLktNEGl4boKXE7aNoRacreJhcE1UR6
AOS7hPZ+6atwiePyF4mJUeb9HZtxa493wk9/Vv6BR9il++1Jz/QKX4oLef8hyBP4
Rb60qgxirG7kBLR+j9zfhskCgYEAzA5y5xIeuIIU0H4XUDG9dcebxSSjbwsuYIge
Ldb9pjMGQhsvjjyyoh8/nT20tLkJpkXN3FFCRjNnUWLRhWYrVkkh1wqWiYOPrwqh
5MU4KN/sDWSPcznTY+drkTpMFoKzsvdrl2zf3VR3FneXKv742bkXj601Ykko+XWM
HcLutisCgYBSq8IrsjzfaTQiTGI9a7WWsvzK92bq7Abnfq7swAXWcJd/bnjTQKLr
rvt2bmwNvlWKAb3c69BFMn0X4t4PuN0iJQ39D6aQAEaM7HwWAmjf5TbodbmgbGxd
sUB4xcCIQQ1mvTkigXWrCg0YAD2GZSoaslXAAVv6nR5qWEIa0Hx9GA==
-----END RSA PRIVATE KEY-----
</key>
I went in to Hybrid VPN on advanced settings. Entered my HMA username and password and then copied the text you sent.  It doesn't work.  I dont understand what happened.  I was having no problem using the VPN until Easter Sunday and then I started getting the slow connection and could not access any games.  I'm not banned or anything because everything works fine if if I dont use the VPN.   This was prior to the PS4 firmware update so it wasnt that.  I also did not change any of my settings from the initial setup with my router.  It just stopped working on PS4 but works fine on PC
I'll have to check with the team and see whether there have been changes to the config files we have/need to get but other than that the only reason I can think of is due to people at home during COVID-19 causing more stress on the servers.
That is not true.  I have a friend that has a Netduma router and he is using his VPN no problem while gaming on the PS4.  This is definitely something wrong with the HybridVpn feature on the router.  I guess I will be returning this for an Asus since those routers actually work
So I found out you guys have know about the slow VPN connection through your Netduma software since 2015 and you still havent fixed it?  This is terrible customer service.  How can you guys advertise features knowing they are faulty?
Here's the link for anyone that wants to read how long they have known about this issue?  And you guys are asking me all of these questions knowing this has been going on for years.
