Abdd Posted April 3, 2020 Posted April 3, 2020 Good evening or good morning I hope that you are all in good health, especially in these days, My problem is simply that I am a new user with R1 router and I am a MW player I updated the device to DUMA OS version Use a feature Geo-Filter to determine the level of PING since I am in the Middle East and there are no really good servers but there are some of them in the process of implementation As I previously explained that serving Geo-Filter works to define the region, but does not work to search that the required PING, and does the exact opposite even though I have blocked several bad servers and activated the Strict Mode feature. I have specified the required level of the area and the level of PING, but it gives me a high and unwanted connection, so what is the solution? Because the reason for purchasing this device is to get the best PING experience The question on the problem of issuing routers Or from the region's servers Or from the game itself, thank you
Sable Posted April 3, 2020 Posted April 3, 2020 1 hour ago, Abdd said: Good evening or good morning I hope that you are all in good health, especially in these days, My problem is simply that I am a new user with R1 router and I am a MW player I updated the device to DUMA OS version Use a feature Geo-Filter to determine the level of PING since I am in the Middle East and there are no really good servers but there are some of them in the process of implementation As I previously explained that serving Geo-Filter works to define the region, but does not work to search that the required PING, and does the exact opposite even though I have blocked several bad servers and activated the Strict Mode feature. I have specified the required level of the area and the level of PING, but it gives me a high and unwanted connection, so what is the solution? Because the reason for purchasing this device is to get the best PING experience The question on the problem of issuing routers Or from the region's servers Or from the game itself, thank you Turn off ping assist
Sable Posted April 3, 2020 Posted April 3, 2020 6 minutes ago, Abdd said: What’s the point ? I need particular Ping !! I don’t think you understand how ping assist works, turn it off and lower your geo filter range to the server you want to play on.
Administrators Netduma Fraser Posted April 4, 2020 Administrators Posted April 4, 2020 Hey, welcome to the forum! What server pings are you getting using Ping Assist? The closest servers to you are probably in Europe so I'd suggest not using Ping Assist and changing the location on the map to that area and trying to force them with the radius.
Abdd Posted April 4, 2020 Author Posted April 4, 2020 I think there is no server near to me , specially in Saudi Arabia , The most good one in Bahrain , and he give me 80 ping always , But sometimes I connect With * peer * connection , With good ping In the end from 100 lobby , 2 is Very good ping , 70 good ping , 28 really bad ping
Administrators Netduma Fraser Posted April 4, 2020 Administrators Posted April 4, 2020 The pings are sort of what I would suspect for your connection. The only way really is to find the ones that play best for you and then force them using the radius/by moving your location.
