Richie Posted November 11, 2019 Posted November 11, 2019 Best , i can not get my normal speed , i have normal download 300 and upload 20 , when i do the test i have just 35 download and upload is wel ok i have try all what they Saïd , only the pppoe settings not , when i look in Device manager i see this 1(POE). Connected Full duplex. 1000mbits Can Somebody help me , my netduma is connected on my modem and then my ps4 whit cable in the netduma , al the rest is Wi-Fi connected on my netduma
Administrators Netduma Alex Posted November 11, 2019 Administrators Posted November 11, 2019 Are you using DumaOS? If so, go to QoS, open the anti-bufferbloat side menu and tick Disable QoS, now see if your speeds improve.
Richie Posted November 11, 2019 Author Posted November 11, 2019 43 minutes ago, Netduma Alex said: Are you using DumaOS? If so, go to QoS, open the anti-bufferbloat side menu and tick Disable QoS, now see if your speeds improve. I am using DumaOS , i have try this disable QoS , works not , wht they mean whit pppoe settings ?
Administrators Netduma Alex Posted November 11, 2019 Administrators Posted November 11, 2019 Does your modem allow you to enter PPPoE settings onto it directly so that you don't have to do it on the R1?
NinaRicci2011 Posted November 11, 2019 Posted November 11, 2019 57 minutes ago, Netduma Alex said: Does your modem allow you to enter PPPoE settings onto it directly so that you don't have to do it on the R1? I have just call whit my provider My modem works not whit PPPoE , i have wel set my netduma wanip in dmz in my Telenet modem , i have test back the Speeds and its hole crazy , Between 60 download and maximum 70 download , and the most crazy part my upload is wel perfect arround 19 and i pay for 20 upload , i now not what speeds i must set in my bandwith , becoz they change hole time
Administrators Netduma Alex Posted November 12, 2019 Administrators Posted November 12, 2019 I would recommend setting your speeds in Anti-Bufferbloat to whatever you pay for, the maximum you can recieve. Then i'd set the sliders to the minimum you get when there's nothing happening on your network.
