mohands Posted October 1, 2019 Posted October 1, 2019 I have reset the router many times and still I connect to people that are not in my circle or ping assist as per the following pictures I use the default settings I have flushed the cloud many times
Administrators Netduma Fraser Posted October 1, 2019 Administrators Posted October 1, 2019 Could you try with Ping Assist at 0 please and see if you're still getting ping assisted hosts please?
mohands Posted October 2, 2019 Author Posted October 2, 2019 the problem I get people with a higher ping value than what I have decided
Administrators Netduma Fraser Posted October 2, 2019 Administrators Posted October 2, 2019 Yeah I know, could you try what I suggested above please as I want to see if Ping Assist isn't working properly at all.
mohands Posted October 2, 2019 Author Posted October 2, 2019 setting it to zero makes every thing working perfectly.
Administrators Netduma Fraser Posted October 2, 2019 Administrators Posted October 2, 2019 So it's not getting you any hosts outside your radius at all? If so put it up to 10ms does it perform the same?
