using xr300 I found the speed is much slower than using modem alone
Hi Wilson,
Your DumaOS settings are correct to push the router to maximum speeds, so the fact they're still so low means something else is wrong.
Are you doing this test wirelessly or wired?
If wireless, have you connected to the 5GHz wireless channel? An easy way to find this out is to go to Device Manager and see which branch your testing device is on.
If wired, are you using the same cables? Are you testing with the same device?
Is there a modem mode or bridge mode option on your modem? Changing it to that might solve your problem.
I have moved this thread to the proper forum section instead of 1v1.
Good catch! I must've missed that 😓
