Netduma R1 Router No Power
Sameer
Last week, I upgraded to DumaOS for my R1 router and it was working fine until this morning I noticed the R1 has no power at all. There was no electric short-circuit smell or any physical damage to it. I tried to plug the adaptor to different socket but no joy. It is dead I guess.
It’s possible that it’s just your power supply that’s faulty. Someone from Netduma will be able to advise you on where to get a replacement.
3 hours ago, Netduma Alex said:
Here's the exact one we use, the diameter of the pin is 2mm.
https://mikrotik.com/product/18POW
If you search 18POW on Google you'll see lots of places that sell it.
I found some options on ebay and this particular adapter is very expensive, around £30. Any idea where I can buy cheaper one? Thank you!
That's great! I mean it's not great that the adapter was at fault but it's great that it's all working now!
