QoS Problems
Flamenation247
for some reason my qos is set to 70/70 but i am receiving my full speeds i made sure the router webpage was not running on any other device the only temporary fix is to factory reset every time it decides to stop working.  I usually us always when using congestion control. ive tried using when high priority traffic is detection but it will not detect nba 2k19 when playing only nor does hyper traffic but it does work for cod and fortnite.
Hi - could you follow this setup guide please:
http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Then if your issues continue, could you take screenshots of your QoS page and post them here. We’ll then check your settings.
