LAN cable not connected, over and over and over. Help!!
dyssonance
Just got the Netduma few days ago and things were working fine, and then...now I keep getting the constant "LAN cable not connected" and its infuriating. All I've done is use the COD settings and then tested expanding my Geo-Filter bit by bit to almost 2000 km (which is dumb, defeats the whole point of this router), and even then I'm still getting disconnects from games.
Any help!?
make sure your cables are all securely plugged into the ports on both ends of the cable. tug on them a tad after you insert them to make sure they're in there right.  if that doesn't work try plugging your cable in a different port. Lastly, swap out the cable for a new one.
Please try this. Also what version of the firmware are you on?
