Using a different A/C power adapter
just wondering if a 9v 0.6a power adapter over the 12v 1a adapter will affect the performance of the router itself, only reason I need to change it is that the uk to nz plug adapter is made poorly and any slight bump will turn it off, thanks in advance :)
Sorry to hear the adapter is not working well.
Honestly, I'm not really sure. It might be ok, but I'm no electrician. The fact the spec is lower than the recommended should mean it won't do any harm (i.e. cause it to be over-powered).
Does it turn on?
