Static IP and Network Settings error " Script error".
R3M!X
Can someone help me figure out how to set up static IP for my devices such as consoles. I can't seem to find this option. Also when I try to load the network settings page I get a script error.
I think reserving IP's is under the Network > DHCP, to set up a static IP for your devices.
As above thats where you do it from. Can you post a screenshot of the error that happens please? When did the error start to occur? Was there anything you changed prior to this?
I've only recently upgraded last Saturday and only last night I actually took a look around the new OS because I was trying to set up a static IP for my Xbox One X. I went through all the tabs and when I went to Network Settings I immediately received the error, I've done no changes to the settings. I will take a screen shot when I get home from work.
Network - DHCP, I'm assuming is where the Network settings tab is that's why I can't find it. Correct?
Yes thats correct its in Network Settings. Can you try accessing it through Google Chrome with any ad blockers disabled please and see if you still see the issue
Ok so I tried on chrome and I got this error
" Uncaught TypeError: Cannot read property 'name' of undefined "
Ahh okay thank you. Aware of this issue and already fixed for next firmware. Workaround for this issue is to reboot and that will fix it.
