Stream Portforwarding Help
It's in Settings > WAN Settings and then you just untick DMZ and it'll be disabled.
This is what how it was when I went to WAN, I think it was already disabled?
Yes that means it's disabled, I would recommend trying it on first to see if it resolves the issue. You need to put the IP address of the device there to apply it correctly.
Switch Nat filtering to open.
This option determines how the router deals with inbound traffic. The Secured option provides a secured firewall to protect the PCs on LAN from attacks from the Internet, but it may cause some Internet games, point-to-point applications, or multimedia applications not to work. The Open option, on the other hand, provides a much less secured firewall, while it allows almost all Internet applications to work.
ElaineM
NETGEAR Community Team
