Speed slow downs.
Hi!
I keep getting speed slow down all the time and the only way I get my speed back up to 70mbps is a reboot. I even disabled al my qos settings and still happens. I tested the speed from yeh modem and no slow downs.
Whats the Mfr and model# of the ISP modem?
Whats the QoS controls set for? Try 99% on the sliders...
Wireless or wired speed testing? Wired is preferred.
Wired and wireless. BT Openreach modem. Tried no QoS and still happens
My previous router was an ASUS RT3200 and had no problems with speed. It’s just that I can have full speed and then my speeds drop to 800kb:s
Try changing MAC address of XR router to previous router as mentioned by Fraser?
What is the mfr and model# of the ISP modem?
I would reload FW clode, then do a full factory reset then set up from scratch. Run some wired tests before setting up anything on the router.
