Preemptive Fiber Gig Speed?
ViciousSavag3
So hey guys im curious to know if u guys have FIXED the Preemptive Algorithm for the Fiber Speed on the R1 router?
Preemptive is for speeds <60Mbps. For higher speeds reactive should be used along with turbo mode/super turbo mode depending on speeds.
I'm not sure which issue specifically you mean, though DumaOS is around the corner and doesn't use these algorithms. It should hopefully work better with fiber :)
Are you the talking about the DumaOs for the R1?
U guys are close to the Release for it? Please tell me YES! SO HYPED LOL
We're close, but again we can't give a date since we are determined to not repeat our mistakes. Overhyping it was half the problem, so try to keep a lid on it til' it's released!
