BIG__DOG Posted June 11, 2018 Posted June 11, 2018 try openwrt forum. It depends on what you want to know regarding setting up lede, you may not get a response as this is involving using an alternative router to XR500 or R1 as that is what this forum is for!
SM961 Posted June 11, 2018 Author Posted June 11, 2018 try openwrt forum. It depends on what you want to know regarding setting up lede, you may not get a response as this is involving using an alternative router to XR500 or R1 as that is what this forum is for! I'm trying to hook up my R1 to mine lede router that's all I can't find any info on the lede forum either that is why I thought I would post here.
BIG__DOG Posted June 11, 2018 Posted June 11, 2018 try this. An old video I made on how I get zero bufferbloat with Lede and R1. It shows you basic setup.......Sorry there is no voice and it is very crudely done but you should be able to follow it!
BIG__DOG Posted June 11, 2018 Posted June 11, 2018 you also should put your charter provided router/modem in modem only mode!
RL317 Posted June 28, 2018 Posted June 28, 2018 Sorry for the bump. I don't have anything on LEDE but if was an interesting watch either way. Quick question - why do you use turbo mode with 80/20 VDSL (or should I say why DID you use turbo if you're not running that setup anymore)?
Dopam-IT_1987 Posted July 1, 2018 Posted July 1, 2018 bonjour vous pouvez regardez mon tutorial si vous voulez il explique pas mal en francais par contre j'ai juste une allow dmz en regle pour ouvrir les ports dans lede pour le r1 j'ai fait deux tuto dont un plus complet
