swoleguy Posted June 17, 2015 Posted June 17, 2015 I just received my Netduma R1 router and followed setup instructions. I'm having problems with the geofilter and network monitor, however. First off, the geofilter by default shows my location in Antarctica (it doesn't recognize my current location like the help tour suggests it should). I changed it to the correct location and continued the tour. After following all instructions in setup, I booted up a game on my Xbox One (Destiny) to test out the geofilter. When joining lobbies, nothing appears on the geofilter map other than my location and the search radius. The network monitor also shows no activity even though the router recognizes multiple devices which were in use. I followed all instructions to a tee, updated to current version 1.03.4, reset and restored factory defaults, set device to Xbox-OS, Xbox Live PA, "Disable" showing on the toggle button, but the geofilter just doesn't seem to be working along with the network monitor. Please help.
boroade Posted June 17, 2015 Posted June 17, 2015 are you using google chrome or explorer im sure it has issues with ie use chrome as when I first got mine had same problem while using internet explorer im no expert though just trying to help
Netduma Staff Netduma Crossy Posted June 17, 2015 Netduma Staff Posted June 17, 2015 Yep, boroade is right. If you're using internet explorer try using Chrome as Chrome is the recommended browser.
AOrtiz Posted June 17, 2015 Posted June 17, 2015 I just had the same problem with my new asus laptop. IE wont display. Google chrome works and displays info
Administrators Netduma Fraser Posted June 17, 2015 Administrators Posted June 17, 2015 Hey swole, as everyone has suggested using Chrome should resolve this. If so let us know how Destiny plays for you as it should be much better. These two guides will help you optimise it for Destiny http://wiki.netduma.com/doku.php?id=destiny_crucible& http://wiki.netduma.com/doku.php?id=destiny_tower
